What is passivation?
Passivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
Passivation involves treating a metal surface with an acid solution to remove free iron and other contaminants to restore the thin, protective oxide layer. This oxide layer acts as a shield, preventing the metal from reacting with its environment and reducing the risk of corrosion. Passivation is commonly used on stainless steel and other metals to improve their resistance to rust, staining, and other forms of deterioration.
Stainless steels are the most common materials that require passivation, which is typically achieved with nitric or citric acid. Anodizing is also a common method of passivation, which is commonly used on aluminum, as well as magnesium and titanium. The protective oxide layer this treatment provides also allows for the metal to be dyed. Read more about how anodizing works.  passivated with nitric or citric acid. Additionally, electropolishing can be used to achieve passivation.
How does passivation work?
The passivation process involves several steps. First, the metal surface is thoroughly cleaned to remove any contaminants. Then, the cleaned metal is immersed in an acid solution – usually a mixture of nitric acid and water – which removes or eliminates free iron and other impurities from the surface.
As the acid reacts with the metal, it triggers the formation of a very thin oxide layer composed of metal oxides – like chromium oxide, in the case of stainless steel. Although this layer is incredibly thin and invisible, it plays a vital role as a protective barrier. By acting as a shield between the metal and the environment, the oxide layer prevents oxygen and moisture causing corrosion or rust.
What materials are used in passivation?
Passivation is commonly used on stainless steel, but it can also be applied to metals like titanium, aluminum, and magnesium in the form of anodizing. The primary focus is on metals that naturally form a protective oxide layer, which contributes to their corrosion resistance. The passivation process is particularly important for stainless steel, where it helps maintain the integrity of the oxide layer on the surface, ensuring continued corrosion resistance.
What are the advantages of passivation?
There are several key reasons for applying passivation to parts as a post process. Here are its benefits.
  • Corrosion resistance. Passivation creates a protective oxide layer on the metal's surface, significantly improving its resistance to corrosion and rust in various environments.
  • Durability. Treated metals have a longer lifespan due to reduced susceptibility to degradation caused by exposure to corrosive agents, moisture, and other environmental factors.
  • Maintained properties. Passivation preserves the inherent properties of metals, such as their mechanical strength and electrical conductivity, while making them more resistant to corrosion-related degradation.
  • Long-term cost savings. By preventing corrosion and the need for frequent replacements, passivation can lead to substantial cost savings over the long term, especially in industries where equipment durability is critical.
What are the disadvantages of passivation?
 While passivation offers numerous benefits, there are also some potential disadvantages to consider. Here are a few of the most common.
  • Complexity. Passivation involves precise control of chemicals, concentrations, and process parameters, which can make it more complex and time-consuming than other surface treatment methods. Additionally, treating large or intricate metal components can be challenging, as ensuring uniform coverage across all surfaces may be difficult.
  • Limited effect on existing damage. Passivation is best suited for preventing corrosion on clean surfaces. It may have limited effectiveness in restoring severely corroded or damaged metal surfaces.
  • Material limitations. Passivation is most effective for metals that naturally form a protective oxide layer. It may not be as suitable for materials that don't readily develop this layer.
Best practices for designing parts for passivation
 By incorporating these best practices, you can increase the likelihood of achieving consistent and effective passivation results for your parts while minimizing potential challenges.
  • Material selection. Choose materials that naturally form a protective oxide layer, such as stainless steel. Avoid materials that might not benefit from passivation or could be adversely affected by the process.
  • Avoid complex shapes. Design parts with simple, accessible geometries. Complex shapes with crevices, corners, and hard-to-reach areas can trap chemicals and hinder proper rinsing during the passivation process.
  • Smooth surfaces. Opt for smooth surface finishes with minimal surface defects. Smooth surfaces are easier to clean and passivate effectively.
  • Eliminate sharp corners. Sharp corners and edges can be difficult to passivate uniformly. Rounded edges are more amenable to passivation and rinsing.
  • Minimize welds. If possible, minimize the number of welds on a part or consider designing them in a way that avoids tight crevices where chemicals might accumulate.
  • Proper drainage. Ensure proper drainage by designing parts to allow liquids to flow freely and not get trapped in recesses. This prevents the accumulation of passivation chemicals.
  • Clearances and gaps. Provide adequate clearances and gaps between components to allow proper chemical circulation and rinsing during the passivation process.
  • Deburring. Remove burrs and sharp edges, as they can harbor contaminants and complicate the passivation process.
Which industries use passivation?
Passivation is widely used in industries such as aerospace, pharmaceuticals, food processing, and electronics to ensure the longevity and reliability of metal components in various applications. Let’s take a look at these industries, and the applications used within them.
  • Pharmaceuticals. Passivation is crucial for pharmaceutical manufacturing equipment, ensuring that stainless steel vessels and piping maintain sanitary conditions and resist corrosion during drug production.
  • Food processing. Passivation is employed in food processing equipment, safeguarding stainless steel tanks and machinery from corrosion, and ensuring compliance with sanitation standards.
 Order parts with passivation
To get an instant quote for a custom part with anodizing as a post-process, upload a CAD file for instant pricing and lead times. Passivation for steel and other metals is available as a custom request. Contact support@hubs.com to discuss your requirements.
You can also read more about post-processing and surface finishes, and how to choose the right process for CNC machined parts
Why is passivation needed?
It prevents corrosion, extends lifespan, and maintains metal properties.
What metals can be passivated?
Stainless steel, titanium, aluminum, and other corrosion-resistant metals are all good candidates for passivation.
Is passivation permanent?
While passivation offers long-term protection, it can degrade over time in aggressive environments.
Can passivated parts rust?
Passivation reduces rust but doesn't eliminate it entirely, meaning upkeep is essential.
Can existing rust be passivated?
Passivation works best on clean surfaces; it's less effective on heavily rusted areas.
Is passivation safe?
When properly managed, yes. However, the passivation process involves handling chemicals and adhering to safety protocols.
What is electroless nickel plating and how does it work?
What is media blasting and how does it work?
How to improve the aesthetics of parts
Type II vs Type III anodizing: what does your project require?
Example of a black oxide part in mild steel
What is black oxide coating?
What is powder coating? Surface finishes for CNC machining
Surface Finishes for CNC Machinining
Post processing for FDM printed parts
Post processing for SLS printed parts
Post-processing for SLS and MJF 3D printed parts
Want to learn about electroless nickel plating? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Want to learn about media blasting? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Find out about the range of surface finishes and materials that make for aesthetically pleasing custom parts.
Learn about the differences between Type II and Type III anodizing, their benefits, typical applications, and how to choose the ideal surface finish for your part.
Want to learn more about black oxide coating? In this article, we’ll take a look at black oxide as a surface finish, its history, common applications, and more
What is powder coating and in what cases should you select it as a finish for CNC-machined metal parts? This article covers the details of the powder coating process, as well as when to choose it for the best performance and quality.
A comprehensive guide describing the range of post-processing options for FDM printed parts
What are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
