CNC turning service
Source high-performing parts in more than 50 different metals and plastics via DTSS-3D network of advanced CNC turning experts. Tight tolerances available, down to ±.0008"
What is CNC turning?
CNC turning produces parts by mounting a blank on a rotating chuck and removing material using stationary cutting tools. This technology is ideal for manufacturing parts with symmetry along their center axis. Turned parts are typically produced faster (and at a lower cost) than milled parts.
Learn more about CNC milling and turning
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/47yo9mm5760W57xNNdBBFF/91f13357b26c827b4e44b7bfdc11fb60/lathe_what_is_cnc_turning.jpg)
Maximum part size for CNC turning
Part size limitations | Metric units | Imperial units |
Maximum part diameter | 431 mm | 17 in |
Maximum part length | 990 mm | 39 in |
Maximum swing over the carriage | 350 mm | 13.7 in |
Maximum spindle through-hole | 40 mm | 1.5 in |
Maximum speed: 1700RPM, Motor power: 640W
Available materials for CNC turning
Industry leading companies in aerospace, automotive, defense, machinery, medical technology, robotics, electronics, oil & gas, industrial automation and more that require high degrees of detail and complexity come to DTSS-3D for rapid prototypes and production parts.
![Example of CNC milling metals](../../images/trans.gif)
A wide range of metals for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
Browse CNC turning metal materials
![Example of CNC milling plastics](../../images/trans.gif)
A wide range of plastics for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
Browse CNC turning plastic materials
CNC turning surface finishes
Enhance part performance by selecting surface finishes that improve the roughness, hardness, chemical resistance and cosmetic features of the finished component.
Browse CNC turning surface finishes
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/55WMaz4rGhh14B7bi5sVoA/ce706482f5d0a64733fe8f6aadeba322/surface_finishes_cnc_machining.png)
CNC turning tolerances
We follow ISO 2768 standards for CNC machining.
Limits for nominal size | Plastics (ISO 2768- m) | Metals (ISO 2768- f) |
0.5mm* to 3mm | ±0.1mm | ±0.05mm |
Over 3mm to 6mm | ±0.1mm | ±0.05mm |
Over 6mm to 30mm | ±0.2mm | ±0.1mm |
Over 30mm to 120mm | ±0.3mm | ±0.15mm |
Over 120mm to 400mm | ±0.5mm | ±0.2mm |
Over 400mm to 1000mm | ±0.8mm | ±0.3mm |
Over 1000mm to 2000mm | ±1.2mm | ±0.5mm |
Over 2000mm to 4000mm | ±2mm |
*Please clearly indicate tolerances for nominal sizes below 0.5mm on your technical drawing.
CNC turning design guidelines
Check the recommended and technically feasible values for the most common features of parts produced with precision CNC turning.
Learn more in our engineering guide to CNC machining
Feature | Recommended size | Feasible size |
Min. feature size | Ø 2.5 mm | Ø 0.50 mm |
Internal edges | R 8 mm | R 0.25 mm |
Minimum wall thickness | 0.8 mm (for metals) 1.5 mm (for plastics) | 0.5 mm (for metals) 1.0 mm (for plastics) |
Holes | Diameter: standard drill bit sizes Depth: 4 x diameter |
Diameter: Ø 0.5 Depth: 10 x diameter |
Threads | Size: M6 or larger Length: 3 x diameter | Size: M2 |
Why should you choose CNC turning?
We have high standards for CNC turning
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to the DTSS-3D standard. A thorough verification of these requirements is included in our inspection report that we ship with every order.
After machining is done, the parts can be left as machined or go through a post-processing process, to improve the properties of the surface and/or achieve nicer, cosmetic looks, as specified in the PO by the customer’s requirements.
In-house quality checks are performed afterwards, before the MP sends the custom parts to our facilities or to their final destinations, to ensure that every part is following the order’s specifications and the DTSS-3D standard.
Any requested documentation is also completed at this stage, assuring the conformity of the parts, before the order is sent out.
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/5DpKdsfhRHEKuuPHdSzkP8/c5137c558a6240dddcc7b81d6610f815/cnc_turning_high_standards.jpg)
More resources for CNC turning
Learn more about how CNC turning works and how to design better parts for this machining process.
