Design for CNC machining
CNC (computer numerically controlled) machining is a robust and high-precision process for manufacturing custom parts. Optimizing the way you design parts can help you get more out CNC's range of milling and turning solutions. This section provides design guidance for reducing costs, speeding up machining times and ensuring parts get produced to your specifications. Learn how to design parts to get the most out of CNC.
How do you deal with sharp corners in CNC machining? Designing with the machinist in mind
Have you designed your parts with sharp corners? They may look good on paper, but they're a nightmare to manufacture with CNC machining. In this article, learn how and why to avoid sharp corners in your designs. It'll reduce lead times, cost and potential headaches for machinists.
How do you select the right materials for CNC machining?
This comprehensive guide compares the 25 most common materials used in CNC machining and helps you choose the right one for your application.
Standard blank sizes for CNC machining (sheets & rods)
Tables of the standard blank sizes (sheets & rods) commonly used in CNC machining.
What is heat treatment and how does it improve CNC-machined parts?
What are the different types of heat treatment and how do they affect CNC-machined parts? This article explores how heat treatments can be applied to many metal alloys to drastically improve key physical properties like hardness, strength and machinability.
How to prepare a technical drawing for CNC machining
How do you prepare technical drawings for CNC machining and why are they important? Technical drawings are widely used in manufacturing to improve the communication of technical requirements between the designer and engineer and the manufacturer.
How to design parts for CNC machining
In this complete guide to designing for CNC machining, we've compiled basic & advanced design practices and tips to help you achieve the best results for your custom parts.
