Surface finishes
Bead blasting services
Bead blasting cleans and evens out the surface of your custom parts, improving the functionality and cosmetic quality. It leaves a uniform matte or satin texture on machined parts by administering high-pressure glass beads on the components. A solely cosmetic option is available on request.
Bead blasted
Requirement | Specification |
Grit | #120 |
Color | Uniform matte of raw material color |
Part masking | Indicate masking requirements in technical drawing |
Cosmetic availability | Cosmetic on request |
![](../../../images.ctfassets.net/q2hzfkp3j57e/3qroOVApGmgqPfEedo29do/61e6bd0aceda38157858d42f59deb308/bead_blastingac45.jpg?fm=jpg&w=1200&h=1200&q=82)
Example of a bead blasted part
![Example of a bead blasted part on Aluminum](../../images/trans.gif)
![Close up on an example of a bead blasted part on Aluminum](../../images/trans.gif)
The DTSS-3D bead blasting process
Here’s how DTSS-3D bead blasts your custom parts:
Parts are first manufactured using a CNC machine
Operators send parts to a bead blaster right after machining
Parts are blasted with glass media (grit #120)
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/5HtXFf1JfE7GKn0I02LaE2/8ccd3c4f8b7271fe61ec3539a18188b3/000_09_02_Bead_blasting.png)
Put your bead blasted parts into production today
