CNC milling service
Source custom parts from our network of specialized CNC milling manufacturers. Source custom CNC milling parts using more than 50 different metals and plastics, available in more than 15 surface finishes. Tolerances down to ±.0008"
What is CNC milling?
CNC milling uses rotational cutting tools to remove material from a workpiece to produce finished parts and products. This manufacturing process works well for many materials, including metals, polymers, wood and glass. CNC milling systems generally have 3 linear degrees of freedom: the X, Y and Z axis. This allows for top-notch precision and detailing. DTSS-3D also offers more advanced, 5-degree systems, where the tool head and machining bed (A and B axis) can also rotate. 5-axis CNC machines can produce parts with high geometric complexity without needing multiple machine setups.
Learn more about CNC milling and turning
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/6yyVaq1xC3TD0oiPghvAZn/98b562ac1838a2b4d7a5adeff8712539/what_is_cnc_milling.jpg)
Maximum part size for 3- and 3+2-axis CNC milling
There are several types of CNC milling machines, each with its own distinct maximum part size. 3-axis and 3+2 axis machines have the lowest start-up costs and can produce parts with relatively simple geometries.
3-axis milling
Size | Metric units | Imperial units |
Max. part size for soft metals [1] & plastics | 2000 x 1500 x 200 mm 1500 x 800 x 500 mm | 78.7 x 59.0 x 7.8 in 59.0 x 31.4 x 27.5 in |
Max. part for hard metals [2] | 1200 x 800 x 500 mm | 47.2 x 31.4 x 19.6 in |
Min. feature size | Ø 0.50 mm | Ø 0.019 in |
[1] : Aluminum, copper & brass [2] : Stainless steel, tool steel, alloy steel & mild steel
3+2 axis milling
Max. part size for soft metals [1] & plastics | 2000 x 1500 x 200 mm | 78.7 x 59.0 x 7.8 in |
[1] Aluminum, copper & brass [2] Stainless steel, tool steel, alloy steel & mild steel
Maximum part size for 5-axis CNC milling
The more advanced of the milling machine family, 5-axis centers can produce parts with more complex geometries. These machines require fewer machine setups so they are more productive.
Max. part size for all materials | 2000 x 1500 x 200 mm | 78.7 x 59.0 x 7.8 in |
Available materials for CNC milling
![Example of CNC milling metals](../../images/trans.gif)
A wide range of metals for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
![Example of CNC milling plastics](../../images/trans.gif)
A wide range of plastics for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
CNC milling surface finishes
Improve your part’s performance by selecting high-quality surface finishes that enhance the roughness, hardness, chemical resistance and cosmetic features of your finished component.
Browse CNC milling surface finishes
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/55WMaz4rGhh14B7bi5sVoA/ce706482f5d0a64733fe8f6aadeba322/surface_finishes_cnc_machining.png)
CNC milling tolerances
We follow ISO 2768 standards for CNC machining.
Limits for nominal size | Plastics (ISO 2768- m) | Metals (ISO 2768- f) |
0.5mm* to 3mm | ±0.1mm | ±0.05mm |
Over 3mm to 6mm | ±0.1mm | ±0.05mm |
Over 6mm to 30mm | ±0.2mm | ±0.1mm |
Over 30mm to 120mm | ±0.3mm | ±0.15mm |
Over 120mm to 400mm | ±0.5mm | ±0.2mm |
Over 400mm to 1000mm | ±0.8mm | ±0.3mm |
Over 1000mm to 2000mm | ±1.2mm | ±0.5mm |
Over 2000mm to 4000mm | ±2mm |
*Please clearly indicate tolerances for nominal sizes below 0.5mm on your technical drawing.
CNC milling design guidelines
Check the recommended and technically feasible values for the most common features encountered in CNC machined parts.
Learn more in our engineering guide to CNC machining
Feature | Recommended size | Feasible size |
Min. feature size | Ø 2.5 mm | Ø 0.50 mm |
Internal edges | R 8 mm | R 0.25 mm |
Minimum wall thickness | 0.8 mm (for metals) 1.5 mm (for plastics) | 0.5 mm (for metals) 1.0 mm (for plastics) |
Holes | Diameter: standard drill bit sizes Depth: 4 x diameter |
Diameter: Ø 0.5 Depth: 10 x diameter |
Threads | Size: M6 or larger Length: 3 x diameter | Size: M2 |
Why should you choose CNC milling?
We have high standards for CNC milling
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to the DTSS-3D standard. A thorough verification of these requirements is included in our inspection report that we ship with every order.
After machining is done, the parts can be left as machined or go through a post-processing process, to improve the properties of the surface and/or achieve nicer, cosmetic looks, as specified in the PO by the customer’s requirements.
In-house quality checks are performed afterwards, before the MP sends the custom parts to our facilities or to their final destinations, to ensure that every part is following the order’s specifications and the DTSS-3D standard.
Any requested documentation is also completed at this stage, assuring the conformity of the parts, before the order is sent out.
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/6hjXREosh1o1Yom6zaTALj/cce1d008e2a1c9a08c38c0b62cf35acb/cnc_milling_standards.jpg)
More resources for CNC milling
Learn more about how CNC milling works and how to design parts to get the most out this machining process.
