SLA 3D printing service
Source high-performing parts for rapid prototyping and production with DTSS-3D’ SLA 3D printing service. We offer tons of prototyping and industrial resin materials and can print parts in as little as 1 day.
What is SLA 3D printing?
Stereolithography (SLA), also known as resin 3D printing, is a 3D printing technology that produces parts with high resolution and accuracy, fine details and smooth surface finishes. Part of the vat photopolymerization printing family, SLA technology uses photosensitive thermoset polymers to produce custom parts. We use Formlabs materials for rapid prototyping and 3D Systems Accura materials for large-scale production.
Learn more about SLA 3D printing
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/2uvc1L3kg50k2a99UebW8H/de4a769b6633ddd80fbcb21ae294459f/manufacturing_with_sla.jpg)
SLA 3D printer capabilities
SLA 3D printing has two distinct classes: prototyping (desktop) SLA and industrial SLA. These are the key capabilities of each technology.
Maximum build size | Standard lead time | Dimensional accuracy | Layer height | Minimum feature size | |
Prototyping (desktop) SLA | 145 × 145 × 175 mm (5.7 in x 5.7 in x 6.8 in) | From 3 business days | ± 0.5% with a lower limit of ± 0.15 mm (± 0.006 in) | 50-100 μm | 0.2 mm |
Industrial SLA | 500 x 500 x 500 mm (19.68 in x 19.68 in x 19.68 in) | From 3 business days | ± 0.2% with a lower limit of ± 0.127 mm (±0.005 in) | 50-100 μm | 0.2 mm |
SLA 3D printed parts come in many materials
Leading companies and engineers that need to iterate quickly or get strong industrial plastic parts faster use DTSS-3D for our range of prototyping and production materials.
Ideal for accurate visual prototypes with smooth surface finishes.
Formlabs Standard Resin
Formlabs Grey
Pro Resin
Formlabs Clear Resin
Formlabs Durable Resin
Formlabs High Temp Resin
Formlabs Flexible Resin 80A (US only)
Formlabs Tough Resin 2000
Formlabs Rigid Resin 4000
Ideal for durable functional prototypes and high precision parts with smooth surface finishes.
Accura ClearVue
Accura Xtreme White 200
Accura 25
Post-processing for SLA
Standard (no additional post-processing)
All support material is removed and support nibs are sanded smooth.
For clear resins, a polishing oil is applied.
Formlabs materials are cured in a Form Cure using the following settings which follow the official Formlabs “Recommended Cure” settings.
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/2qFmsWf00YNr9g5WsRYy1m/46637f17399527bf88a1adeaaa958329/post_processing_sla.jpg)
Formlabs Cure settings
Resin | Post-cure time | Post-cure temperature |
Standard clear | 15 min | 60 °C |
Standard black | 30 min | 60 °C |
Standard white | 30 min | 60 °C |
Standard gray | 30 min | 60 °C |
Tough 2000 | 60 min | 70 °C |
Durable | 1 hour | 60 °C |
Grey pro | 15 min | 80 °C |
High temp | 2 hours | 80 °C |
Flexible | 15 min | 60 °C |
Rigid | 15 min | 80 °C |
How SLA stacks up against other 3D printing technologies
Materials | Price | Dimensional accuracy | Strengths | Build volume | Layer thickness | Min. feature size | |
FDM | 5 | $ | ± 0.5% with a lower limit on ± 0.5 mm | Low cost, wide range of materials | 500 x 500 x 500 mm (19.68" x 19.68" x 19.68") | 100-300μm | 2.0 mm (0.0787'') |
Industrial FDM | 6 | $$$$ | ± 0.25% with a lower limit: ± 0.25 mm (± 0.010") | High level of repeatability, engineering grade materials | 406 x 355 x 406 mm (15.98” x 13.97” x 15.98") | 100-330μm | 2.0 mm (0.0787'') |
Prototyping SLA | 8 | $$ | ± 0.5% with a lower limit of ± 0.15 mm (± 0.006")/ | Smooth surface finish, fine feature details | 145 × 145 × 175 mm (5.7" x 5.7" x 6.8") | 50-100μm | 0.2 mm (0.00787'') |
Industrial SLA | 3 | $$$ | ± 0.2% with a lower limit of ± 0.127 mm (±0.005") | Smooth surface finish, fine feature details, big print area | 500 x 500 x 500 mm (19.68" x 19.68" x 19.68") | 50-100μm | 0.2 mm (0.00787'') |
SLS | 2 | $$ | ± 0.3% with a lower limit of ± 0.3 mm (± 0.012”) | Design flexibility, supports not required | 395 x 500 x 395 mm (15.53" x 19.68" x 15.53") | 100μm | 0.5 mm (0.0196”) |
MJF | 2 | $$ | ± 0.3% with a lower limit on ± 0.3 mm (0.012'') | Design flexibility, supports not required | 380 x 285 x 380 mm (14.9'' x 11.2'' x 14.9'') | 80μm | 0.5 mm (0.0196”) |
Why should you choose SLA 3D printing?
We have high standards for SLA 3D printing
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to the DTSS-3D standard. A thorough verification of these requirements is included in our inspection report that we ship with every order.
Parts are fully cured to material manufacturer specifications before shipping.
Hollow sections are drained of excess resin.
All support material is removed and support nibs must be sanded smooth.
![DTSS-3D,3D printing,3D printing services,SLM 3D printing,SLA 3D printing,SLS 3D printing,Metal 3D printing,CNC machining,sheet metal processing](../../../images.ctfassets.net/q2hzfkp3j57e/7vN36RnTqWhGZdDDBkn5bv/fc22e672afe20f27151f027ecc63ee2e/SLA_standards.jpg)
Advantages and drawbacks of SLA 3D printing
![Advantages of SLA](../../images/trans.gif)
SLA can produce parts with very high dimensional accuracy and intricate details.
SLA parts have a very smooth surface finish, making them ideal for visual prototypes.
Speciality SLA materials are available, such as clear, flexible and castable resins.
![Drawbacks of SLA](../../images/trans.gif)
• SLA parts are generally brittle and not suitable for functional prototypes, though industrial SLA can produce more functional components for this stage.
• The mechanical properties and visual appearance of SLA parts will degrade over time when the parts are exposed to sunlight.
• Support structures are always required and post-processing is necessary to remove the visual marks left on the SLA part.
Design guidelines for SLA
3D printing
This table summarizes the recommended and technically feasible values for the most common features of SLA 3D printed parts.
Read more about how to design for 3D printing
Feature | Recommended size |
Unsupported walls | 1.0 mm (0.0393 in) |
Supported walls | 0.5 mm (0.0197 in) |
Minimum feature size | 0.2 mm (0.00787 in) |
Minimum hole diameter | 0.5 mm (0.0197 in) |
Minimum escape hole diameter | 4.0 mm (0.157 in) |
More resources for SLA
3D printing
Learn more about how SLA 3D printing works and how to design parts for this adaptive additive manufacturing technology.
Introductory guides |
Our other 3D printing processes
![3D printed part in FDM process](../../../images.ctfassets.net/q2hzfkp3j57e/3vq5CaEYGhwH2gtQZCn7oQ/3426cfc8f99df999fddb004989530a47/fdm_capabilities7ae7.png?fit=thumb&fm=png&q=82)
Fast & affordable prototyping
Dimensional accuracy of ± 0.05% with a lower limit: ± 0.05 mm
Lead times from 1 business day
![3D printed part in MJF process](../../../images.ctfassets.net/q2hzfkp3j57e/54nsXHICMJEjYLtzjr63Gy/2cc40818b6fb120dcb0563d193ec40b3/mjf_capabilities7ae7.png?fit=thumb&fm=png&q=82)
Functional prototyping & low-run production
Dimensional accuracy of ± 0.3% with a lower limit on ± 0.3 mm
See our MJF services![3D printed part in SLS process](../../../images.ctfassets.net/q2hzfkp3j57e/4U0hbO2DaDK0ikTJC3DOd4/5ff8196059e48fde69b062d321cbaf9d/sls_capabilities7ae7.png?fit=thumb&fm=png&q=82)
Dimensional accuracy of ± 0.3% with a lower limit of ± 0.3 mm (± 0.0118")
See our SLS services
