Post processing for SLA printed parts
A comprehensive guide describing the range of post-processing options for SLA printed parts
SLA 3D printing is capable of producing prints with fine details and feature as small as 0.3 mm. The biggest drawback to this technology is that parts are often small and most prints need to be oriented at an angle and require support structures to be attached to the model. These supports leave marks on the surface and create uneven surfaces. Fortunately, most SLA resins are one of the easiest 3D printed materials to post process. SLA resins allow for a range of finishing options with the most common of these described in this article.
Note: All images in the examples below are printed with clear resin at 50 micron layer height.
An electronic enclosure with a clear SLA top cover post-processed to a range of different finishes
Curious about the cost and the available material options for SLA?
Get instant quote See all SLA materials
Basic support removal
Process: The support structure is broken off or cut from the model leaving a bumpy surface on the surfaces in contact with support material. If a high quality surface finish is required adding extra material (at least 0.1 mm) to be sanded afterwards allows for better dimensional accuracy.
Pros
Gives the customer complete control over the finish.
For critical vertical hole diameters drilling after printing is recommended if high accuracy is desirable.
Highest accuracy as overall geometry is not altered
Cons
Not aesthetically pleasing
High level of skill required to achieve a clean finish
Finish ☆ ☆ ☆ ☆ ☆
Tolerances ★ ★ ★ ☆ ☆
Speed ★ ★ ★ ★ ★
Suitable for All SLA resins
Sanded support nibs
Process: Only the small support nibs are sanded off. This process is suited for flat surfaces where it is easy to judge the surface is flat. Because the surface is only sanded at the support nibs the overall geometry of the parts is generally unaffected.
Pros
Accurate surface (gives geometry that is close to the 3D model)
Resulting matte finish hides imperfections
Cons
Can result in uneven surfaces on side where support was located (due to non-uniform sanding)
Not aesthetically appealing (particularly on clear resin)
Finish ★ ☆ ☆ ☆ ☆
Tolerances ★ ★ ★ ★ ☆
Speed ★ ★ ★ ★ ☆
Basic support removal (left) and sanded support nibs (right)
Wet sanded
Process: Wet sanding generally achieves the smoothest surface finish (depending on the number of sandpaper graduations used). On the unsupported side of the model, only the build lines need to be sanded. This can typically be achieved with a single high grade of sandpaper (no graduation needed) making the finish a lot cheaper. The supported side is more labor intensive typically requiring at least 4 sandpaper graduations. It is, therefore, best practice to place the supports on the least visible part of the model. Depending on the support placement there may be some accuracy loss as material is removed through the sanding process.
Pros
Excellent smooth finish
Ideal for complex geometries
Best surface preparation for painting
Cons
Lower accuracy on supported side
Water used while sanding can result in some white/light spots on the print
Finish ★ ★ ★ ☆ ☆
Speed ★ ★ ★ ☆ ☆
Mineral oil finish
Process: This finish is similar to the wet sanded finish with the exception of a mineral oil layer added after the sanding process. The mineral oil helps to hide the white/light spots on the model creating a nice even finish.
This finish is well suited for mechanical parts reducing friction and lubricating the surface.
Pros
Results in a semi transparent finish for clear resins
Cons
Paint does not adhere well to surface
Finish ★ ★ ★ ☆ ☆
Speed ★ ★ ★ ☆ ☆
Wet sanded (left) and mineral oil finish (right)
Spray paint (clear UV protective acrylic)
Process: Spray painting the model helps to conceal layer lines reducing the need to sand the unsupported side of the model. The varnish also protects the model from yellowing and post curing by limiting UV exposure.
Acrylic paint will not adhere well to flexible resin. If flexible resin needs to have a glossy finish coating with a thin layer of resin then curing underwater can achieve this, however, this affects tolerances and details dramatically.
Pros
Clear finish on complex geometries for clear resin
Offers UV protection
Cons
Typically results in an ‘orange peel’ effect on the surface
Increases overall dimensions
Not suited for sliding or moving parts
Finish ★ ★ ★ ★ ☆
Tolerances ★ ★ ☆ ☆ ☆
Speed ★ ★ ☆ ☆ ☆
Polished to clear transparent finish
Process: The surface is sanded using increased grit levels of sand paper (concluding with 2000 grit). The surface is then polished with a polishing compound. This results in the most clear surface possible but it is very time consuming and only possible on surfaces that can be sanded easily.
This finish is well suited for simple shapes with few details (like the crystal of a watch). It is less suited for models which need a clear finish on both sides with complex geometries like ribs and small spaces.
This finish may not be suitable for tough and flexible resin as they are softer than the other resins.
Pros
Clear finish (comparable to glass)
Very smooth surface
Cons
Labour intensive
Not possible with complex geometries
Finish ★ ★ ★ ★ ★
Speed ★ ☆ ☆ ☆ ☆
Suitable for Clear resin. Can be used on engineering and coloured resins but typically not necessary
Spray paint (clear UV protective acrylic) (left) and polished to clear transparent finish (right)
What is electroless nickel plating and how does it work?
What is media blasting and how does it work?
How to improve the aesthetics of parts
What is passivation?
Type II vs Type III anodizing: what does your project require?
Example of a black oxide part in mild steel
What is black oxide coating?
What is powder coating? Surface finishes for CNC machining
Surface Finishes for CNC Machinining
Post processing for FDM printed parts
Post processing for SLS printed parts
Post-processing for SLS and MJF 3D printed parts
Want to learn about electroless nickel plating? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Want to learn about media blasting? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Find out about the range of surface finishes and materials that make for aesthetically pleasing custom parts.
Passivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
Learn about the differences between Type II and Type III anodizing, their benefits, typical applications, and how to choose the ideal surface finish for your part.
Want to learn more about black oxide coating? In this article, we’ll take a look at black oxide as a surface finish, its history, common applications, and more
What is powder coating and in what cases should you select it as a finish for CNC-machined metal parts? This article covers the details of the powder coating process, as well as when to choose it for the best performance and quality.
A comprehensive guide describing the range of post-processing options for FDM printed parts
What are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
