What is heat treatment and how does it improve CNC-machined parts?
What are the different types of heat treatment and how do they affect CNC-machined parts? This article explores how heat treatments can be applied to many metal alloys to drastically improve key physical properties like hardness, strength and machinability.
Heat treatments for CNC machined parts
Heat treatment involves the heating of metal alloys to (usually) extreme temperatures, followed by a cooling step under controlled conditions. The temperature the material is heated to, the time it is kept at that temperature and the cooling rate all greatly affect the final physical properties of the metal alloy.
Heat treatments can be applied to many metal alloys to drastically improve key physical properties, including hardness, strength and machinability. These changes happen due to modifications to the microstructure and, sometimes, the chemical composition of the material.
In this article, we review the heat treatments that are relevant to the most commonly used metal alloys in CNC machining to help you choose the right material for your applications.
Learn how to design better, more cost-efficient parts for CNC machining?
Our CNC design guidelines Tips for reducing CNC costs
What is heat treatment in CNC machining?
An integral step in CNC machining metal parts, heat treatment is the process of controlled heating and cooling of a material to achieve desired material properties. It alters four of the main material properties of metal parts, which are hardness, strength, toughness and ductility.
Of course, not all heat treatments are created equal. You choose the ideal heat treatment method based on the material composition, size of the part you’re producing and the required final material properties.
The goal of heat treatment is to achieve a particular microstructure that gives your parts certain material properties.
When should you apply heat treatments to metal parts?
You can apply heat treatments to metal alloys at several stages of the CNC machining process, either before you start machining your parts or after.
Before CNC machining
When a standardized grade of a metal alloy is requested that is readily available, the CNC service provider will machine the parts directly from that stock material. This is often the best option for reducing lead times.
After CNC machining
Some heat treatments significantly increase the hardness of the material or are used as a finishing step after forming. In these cases, the heat treatment is applied after CNC machining, as high hardness reduces the machinability of a material. For example, this is standard practice when CNC machining tool steel parts.
What are common heat treatments for CNC materials?
Annealing, stress relieving & tempering
Annealing, tempering and stress relieving all involve the heating of the metal alloy to a high temperature and the subsequent cooling of the material at a slow rate, usually in air or in the oven. They differ in the temperature that the material is heated to and in the order in the manufacturing process.
In annealing, the metal is heated to a very high temperature and then slowly cooled to achieve the desired microstructure. Annealing is usually applied to all metal alloys after forming and prior to any further processing to soften them and improve their machinability. If another heat treatment is not specified, mo
st CNC machined parts will have the material properties of the annealed state.
Stress relieving involves the heating of the part to a high temperature (but lower than annealing) and is usually employed after CNC machining, to eliminate the residual stresses created from the manufacturing process. This way parts with more consistent mechanical properties are produced.
Tempering also heats the part at a temperature lower than annealing, and it's usually employed after quenching of mild steels (104
5 and A36) and alloy steels (4140 and 4240). This reduces their brittleness and improves their mechanical performance.
Heat treatment Purpose Compatible materials
Annealing To improve the machinability of the metal alloy All metal alloys
Stress relieving To release residual stresses from mechanical deformation or temperature increase during processing All metal alloys
Tempering To reduce brittleness after quenching Mild steels (1045, A36) Alloy steels (4140, 4240) Tool steels (A2)
Quenching
Quenching involves the heating of the metal to a very high temperature, followed by a rapid cooling step, usually by dipping the material in oil or water or exposing it to a stream of cool air. Rapid cooling "locks in" the changes in the microstructure that the material undergoes when heated up, resulting in parts with very high hardness.
Parts are usually quenched as a final step in the manufacturing process after CNC machining (think of blacksmiths dipping their blades in oil), as increased hardness makes the material more difficult to machine.
Tool steels are quenched after CNC machining to achieve their very high surface hardness properties. A tempering process may then be used to control the resulting hardness. For example, Tool steel A2 has a hardness of 63-65 Rockwell C after quenching but can be tempered to a hardness ranging between 42 to 62 HRC. Tempering prolongs the service life of the part, as it reduces brittle
ness (best results are achieved for hardness of 56-58 HRC).
Quenching To increase the hardness of the metal alloy Mild steels (1045, A36) Alloy steels (4140, 4240) Tool steels (D2, A2, O1)
Precipitation hardening (aging)
Precipitation hardening or agin
g are two terms commonly used to describe the same process. Precipitation hardening is a three-step process: the material is first heated to a high temperature, then quenched and finally heated to a lower temperature for a long time (aged). This causes the alloy elements that initially appear as discrete particles of different compositions to dissolve and distribute uniformly in the metal matrix, in a similar way to how sugar crystals dissolve in water when the solution is heated.
After precipitation hardening, the strength and hardness of the metal alloys increase drastically. For example, 7075 is an aluminum alloy, commonly used in the aerospace industry, to manufacture parts of tensile strength comparable to stainless steel, while having less than 3 times the weight.
The effects of precipitation hardening in aluminum 7075 are illustrated in the next table:
Aluminum 7075-0(tempered) Aluminum 7075-T6(precipitation hardened)
Ultimate Tensile Strength 280 MPa 510–540 MPa
__Yield Strength __ 140 MPa 430–480 MPa
__Elongation at Break __ 9-10% 5–11%
Hardness (HV) 68 175
Not all metals can be heat treated with this method, but the compatible materials are considered superalloys and are suitabl
e for very high-performance applications. The most common precipitation hardening alloys used in CNC are summarized below:
Precipitation hardening (aging) To increase the hardness & strength of the metal alloy Aluminum alloys (6061-T6, 6068-T6, 7075-T6) Stainless steel (17-4)
Case hardening & carburizing
Case hardening is a family of h
eat treatments that result in parts with high hardness, while the underline materials remain soft. This is often preferred over increasing the hardness of the part throughout its volume (for example, by quenching), as harder parts are also more brittle.
Carburizing is the most common case-hardening heat treatment. It involves the heating of mild steels in a carbon-rich environment and the subsequent quenching of the part to lock the carbon in the metal matrix. This increases the surface hardness of steels in a similar way that anodizing increases th
e surface hardness of CNC aluminum parts.
Case hardening & carburizing To increase the surface hardness of the metal part, while keeping the core soft Mild steels (1018, A36)
How to specify a heat treatment on CNC orders with Protolabs Network
When you place a CNC machining order, there are three ways to request a heat treatment:
Give a reference to a manufacturing standard: Many heat treatments are standardized and widely used. For example, the T6 indicator in aluminum alloys (6061-T6, 7075-T6 and so on) shows that the material has been precipitation hardened.
Specify the required hardness
This is a common method of specifying a heat treatment for tool steels and case hardening. This will indicate to the manufacturer the heat treatment he needs to perform after CNC machining. For example, for D2 tool steel, it is common to request a hardness of 56-58 HRC.
Specify the heat treatment cycle
When the specifics of the required heat treatment are known, then these can be communicated to the supplier when placing the order. This way you can specifically modify the material properties for your application. Of course, this requires advanced metallurgical knowledge. We can help with all of these specifications.
Upload your design for a free, instant quote
What are the different types of heat treatment?
There are four common methods for heat treatment, which include annealing, hardening, quenching and stress relieving.
What’s the purpose of heat treatment?
As heat treatment changes the microstructure of metals and alloys, it provides several benefits to the lifecycle of CNC-machined parts. Heat treatment is used to increase a part’s surface hardness, strength and ductility, and improve its temperature resistance.
What are the different types of annealing?
There are seven types of annealing, which include complete, isothermal, incomplete, spherification, diffusion (uniform), stress relieving and recrystallization annealing. Annealing often improves machinability, as well as the electrical and magnetic properties of a part.
What are the advantages and disadvantages of heat treatment?
Heat treatment provides many advantages for CNC-machined parts. This process helps manufacturers improve a part’s mechanical and chemical properties while reducing and preventing stress and distortion. Of course, heat treatment comes with its share of disadvantages, which include additional costs, surface oxidation and potential other contamination.
How do you specify heat treatment for CNC parts on the Protolabs Network platform?
You can specify a heat treatment in your CNC machining order as a “Custom requirement” by referencing a specific material temper, by providing a hardness requirement, or by describing a treatment cycle. Our mechanical engineers will review additional specifications you enter and may update the price.
How do you deal with sharp corners in CNC machining? Designing with the machinist in mind
cnc-surface finish-as-machined-1
What are the different types of threads for manufacturing? Practical tips for engineers
Standard Blank Sizes for CNC machining (Sheets & Rods)
Standard blank sizes for CNC machining (sheets & rods)
Selecting the right CNC material
How do you select the right materials for CNC machining?
How to prepare a technical drawing for CNC machining
How to design parts for CNC machining
Minimizing the cost of CNC parts (13 proven design tips)
14 proven design tips to reduce the cost of CNC machining
Have you designed your parts with sharp corners? They may look good on paper, but they're a nightmare to manufacture with CNC machining. In this article, learn how and why to avoid sharp corners in your designs. It'll reduce lead times, cost and potential headaches for machinists.
What are the different types of threads for manufacturing? In this article, learn how to correctly design threads to reduce lead times and cost for your next CNC machining production run.
Tables of the standard blank sizes (sheets & rods) commonly used in CNC machining.
This comprehensive guide compares the 25 most common materials used in CNC machining and helps you choose the right one for your application.
How do you prepare technical drawings for CNC machining and why are they important? Technical drawings are widely used in manufacturing to improve the communication of technical requirements between the designer and engineer and the manufacturer.
In this complete guide to designing for CNC machining, we've compiled basic & advanced design practices and tips to help you achieve the best results for your custom parts.
Make the most of CNC machining by optimizing your design and making the right material choices. Read these 14 design tips to help you reduce CNC-machining costs and create the perfect parts for your project.
