Hi really hoping someone can help. My Zprinter 450 no longer boots, when i turn on the machine it beeps 3 times pauses and repeats. There is also no text on the LCD just a blank white box. If anyone knows what the beeps mean or if there is anyway of running a system check that would be greatly appreciated.
Hi, Thank you both for the reply. I’ve now fixed the problem it was a dead stick of Ram. I’m now back to the original issue i was facing before i posted on here. I keep getting HP11 continuity check failed error code 40800, I’ve already thoroughly cleaned pinheads, pogo pins and connectors. Tried multiple new pinheads, bought a new pogo card and carriage ribbon cable but to no avail. I’ve manually checked most of the cables on the machine for continuity but everything seems fine.
Hello, May I ask you the documentation that you were proposing to Aaran to reset the motherboard? I bought recently a Zprinter450. I had recently to change the battery of the motherboard. Since then once the printer is online, as soon as I connect it to a router to put it on the network, the printer hangs up and does not react anymore. May be that the motherboard needs to be reset. I would really be happy if you could share this documentation. Today I am pretty much stuck and I did not have yet the chance to print any single part. Kind regards Mourad from Switzerland
I have a MiiCraft 125 3D printer. it worked just fine until 2 weeks back. after I switched it off and tried switching it on the next day, it won’t boot past the power on that flashes across the screen. Need help. could it be a motherboard issue? also how do I fix it?
the solution that you proposed will it work for my printer too?
hi! I have almost the exact same problem… I replaced the CMOS battery and pogo card. Hardware seems to work as long as i dont connect LAN. Have attached vga,keyboard to the 450, everything is locking up when i connect LAN. I am suspecting wrong bios settings. Are you able to send me the correct settings? Best regards, Jon Christian
Hi Christian, As you say, i had the same problem as you. I can tell the end if the story. Actually i tried many things unsuccessfully. I finally asked a 3d system representative to have a look. Bios was fine. He tried to fix the problem unsuccessfully as well. He recommanded me to buy a new motherboard, which i did. Once installed, the printer works fine since then…
Hey so I’ve bought a zcorp 450 printer and it may need a new mother board due to the heat sink falling off and frying the board. On a post on here it says you bought a new mothe board for yours. Can I ask how much you paid for it and where you bought it from?
