What is the transparent resin with highest resolution so far on the market?
I would like to print highly transparent parts using Kudo3D Titian2 HR using its highest resolution setting (XY resolution 23um, layer height 5 um). But the recommended clear resin on Kudo3D official website is the Autodesk Clear, which is compatible with only 100um XY resolution. Could anyone recommend some transparent resin which is compatible with high resolution settings of XY 23 um? Thanks!
Hi Ye, sometimes resolution doesnt correlate with transparency and most of the time transparency depends on how you post process your part!
here is an article from the formlabs team making camera lenses which address transparency
hi sir:
iam also looking for the same resin you required , please if you find any resin just send to me urgently
thanks
mohamed shanash
