Water Cooling 3d Print Head
Hey Guys/Gals,
Thought I would announce a new printer mod which is currently on Indiegogo (Kickstarter to follow)
Makes life easy to convert a V6 (Either Original Or Clone) in to a fully water cooled setup, all you need is the Heat Brake (M7 Thread) and your regular Heat Block (Nozzle, Thermistor+Heat Cartridge)
Link below to Indiegogo:
Fitment is easy, uses standard PC Cooling accessories (Water Pump and Radiator+Fan)
Useful for doing away with the noisy and unreliable fan on the V6 for which the bearings commonly fail, perfect if using an enclosure as hot air being blown at the standard heatsink is not very efficient.
Regards
