Is it possible to print with creatbot dual extruder two different filaments in one print ?
It depends on what you are trying to print together. Of course pla with pla or abs with abs works but there is also dissolvable filaments that can be used.
You might have to stick with similar temperature materials so the radiant heat from one doesn’t clog the other and have to have similar conditions on the bed that allows adhesion for both filaments.
I have never tried pla with abs.
i was thinking one that is water or alcohol dissolving and the other like petg or pla .Thanks for the respond
That would definitely work. Makerbot also makes a filament that dissolves in lemonine, aka the acid in lemon juice.
Great good to know thanks. the fdm printers are almost maxed its filament battle now
Any idea how to divide the infill and the exterior on the slicer(cura is what i use) to use different material in a dual extruder printer ?
