Hello, I am new to 3d printing and I am having problems slicing my file. The progress bar gets filled up and then it says 0 min to print which is obviously incorrect. I assumed the polygon count was too high so I used decimate to lower it by about 30-40% which helped cura slice it but removed so much detail that it was not helpful. The file called “smallest4layer” is the original stl file that I am trying to stack on top of itself a few times to create a filter, but I am unable to slice even the 4 layer version. The file called “smallest128layerdecimate” is the desired final product after using decimate which sliced and printed fine but was too far off from my original design. I am getting extremely frustrated with this, so any help would be greatly appreciated.
Thanks in advance
smallest4layer.stl (981 KB)
smallest128layerdecimate.stl (18.4 MB)
