is there an way to change the top and bottom layer thickness or number of layers that are printed in replicatorG? The top layer is kind of wavy and I think if it were thicker it would solve my issue. Any suggestions?
Usually your slicer allows you to change the number of top and bottom layers as well as the perimeters. If your sliver doesn’t then this setting might be called “outer shell thickness”. What slicer are you using?
Skeinforge 50 with ReplicatorG 0040
1. I use slic3r which has these setting available.
2. If your top layers are wavy it’s because they’re probably smaller and not having enough time to cool before the next layer is printed. The solution is cooling with fans, slowing the print, lowering temp or some combination of the three.
-Jesse
