[Solved] Nozzle scraping baseplate
I have a Monoprice Maker select v2 and I am trying to set it up, but I got to step 14, which is:
loosen the nut at each corner of the baseplate until it is almost touching the nozzle. Do the same at each corner.
That worked for the bottom left corner, but no matter how much I tighten both right corners, the nozzle still scrapes the plate when I move it to those corners.
It is in home position and there is nothing putting it off or tilting it.
