Hello, it is possible to make an oblique cylinder in tinkercad ?
Thanks to all
Thanks to all
Thats a good question! I havent found a tool that allows you to skew one side of a part, but what I would do is make a cyllinder, rotate it on the vertical axis until you reach the degree of ‘obliqueness’ you want. Then use 2 block holes- one on top and one on bottom. Since those sre parrallel to eachother, when you delete from the cyllinder, it will have that skewed look.
try using a360 fusion or I can model it for you as a favour if you email me a sketch
Hey Samos -
Not sure if you posted to the Tink forum also, but here’s a solution I put up yesterday: https://support.tinkercad.com/hc/en-us/community/posts/206866248-Shape-Request-Oblique-Cylinder
