When doing this like this its best to scale up the part you want to use it does not have to be much 0.1 - 0.2 % is usually enough then you want to subtract the enlarged part from the solid. just to clarify I meant to copy and scale up the part you want to subtract which is your white part, put it in position and remove it from your orange part then delete the scaled part and continue to use your normal size parts.
