perimeter shells not bonding well in places
Hello,
I am using simplify3d. How can I increase the bonding for the perimeter shells. I am running into problems were the shells don’t bond well with each other. I guess I only have two perimeter shells on this print. But I can, at the top, separate the two with my fingernail.
Thanks,
Mike
Check the model to see how thick the wall is and what you have the extrusion width set at. For instance If I have a wall that is 1mm thick and my extrusion width is set at .4 then there is a .2 gap. I set the extrusion width to .39 and it fixes it. Or, change the dimension of the thin wall to be a multiplier of the extrusion width.
You can see it in S3D print preview.
