Looking to get this design 3D printed
never used a 3D printer and need some advise I need the 3D holder for the carrot to open and close to be able to get the carrot out. Also need a demo carrot made. And I also need it to fit a real carrot in it
Looking for someone to design and print it, also have another project to been done as well
looks like a pretty basic design, do you have a drawing with dimensions required. What type of material will be required for the print ?
I don’t have any drawings but the dimensions should be taken from a large carrot, also the plastic should be clear.
Adam,
I did different designs and prints for the argicutural sector. If you send me some drawings i can give you advice and make a price indication for you.
Adam,
You can drop the drawing to my hub “Saenhub” as an inquiry and i will have a look
https://www.3dhubs.com/amsterdam/hubs/saen
cheers
Hi guys the only image/drawings I have is the one shown in the post
Carrots ar different in sizes and this design can be opened . Its your resonsibility to determine the dimensions.
In drawing and printing everything is possible but is costs time and money.So you have to be more specific!
Where is it used for, simply display or for operational use?
Something like this, Adam
Sort of but the carrot grow to the size of the container it’s use is to make carrots straight
OK then you pick the size wich is acceptable for the consumer! and this can be drawn internaly
Let’s base it on the fact that a carrot is 20cm long, with a circumference of 12 cm? And tapering down to a point leaving enough room for the roots out the end of the sleeve
The fact is I just need an approximate size demo model
This is what I’m looking for but the sleeve the carrot is in needs to fit tight around the carrot I also need that carrot printed
If you tell me the size of the carrot you want i can design a carrot and a carrot growcover
Please send an inquiry on my hub with sizes of the carrot you like and i make a quote, with design and printing costs
ok forgot to read the last post, lust mail an inquiry on my hub and i already have a carrot in my library
It would be cool if someone would design this for those fork elusive carrot:
