Hope someone can make it or help.
__Volume_Snaka_Design.stl (613 KB)
Hey @Yosi,
I am not sure if this is exported correctly because this is really really really small. If you indeed need this at this size then it will be very difficult to find someone who can print a functional part of this size.
What should be the size of this print?
I hope the dimensions are just in the wrong order of magnitude. If it’s “normal” size, then it’s a super-easy print.
Hi Arnoldas
The dial is 21,6 mm long an 8,5 mm high. Is this a problem? I would like it in metal but is open for different materials.
Hi Josh
The dial is 21,6 mm long and 8,5 mm high. Is this a problem? I would like it I metal but is open for other materials.
This actually looks like a really simple print. I can’t do metal so I can’t help with that, but it is definitely printable.
I can do ABS, PLA, or Resin.
Hi Marco
What will you recommend for this project the dial should be used in a car.
Need it in black.
For high precision I recommend resin. It’s also a lot less sensitive to heat than ABS or PLA. What part of the car is the dial for?
If you’d like you can take a look at my hub at: https://www.3dhubs.com/new-york/hubs/obsessively-geek
and/or email me at marco@og3dprinting.com
If it’s going in a car and you’d want to do at least ABS since it has a higher “melting” temp.
Thanks.
What will it cost for two (Resin samples) - delivered to Denmark?
Send me an email and we can talk further including shipping quotes. Thanks.
