I need someone to separate the face plate from the rest of the helmet. I need the two pieces to fit as closely as possible too. I will then 3-D print this. Thanks so much!
iron_mask_onepiece_0.stl (10.4 MB)
Here you go
iron_mask_onepiece_0_0.stl (3.3 MB)
iron_mask_onepiece_0(2).stl (4.38 MB)
iron_mask_onepiece_0(3).stl (2.7 MB)
Thank-you so much! How well do these fit together? How well do the seams line up? The original helmet that you separated was not lined up right. Is there a way to line these up in the way it should be?
Hey Kyle,
I just split the model into separate files for the three solid bodies. The model is otherwise unchanged. If you need the model altered then it’s time to get your hands dirty and do some sculpting or find someone you can pay to do it for you. There aren’t any “automatic” tools that will do this for you.
Cheers,
Marc
