How to fix No EP Cartridge on HP Printer?
The No EP Cartridge error on your HP Printer generally indicates that there is a technical error with the toner cartridge or the DC controller. You can refer to the steps below to fix the No EP Cartridge error on HP Printer:
·Reset the toner cartridge on your printer or try a new one
·Check the High Voltage Contacts and see if there is any damage.
·Replace the High Voltage Power Supply and reseat the HVPS cable
·Replace the DC Controller on your HP Printer and print a test document
If you find that the error persists even after implementing the steps mentioned above you can call the Hp Printer support and ask for additional technical assistance.
For More:-
Hp Printer support phone number
