Help with converting a dwg file to a stl file
I wounder if it’s possible to convert a dwg file to a stl file so I can 3d print it.
In Autocad, just export as stl. If you don’t have Autocad, ask someone who does or Google for a converter. I’m sorry I can’t recommend a specific converter but I don’t use Autocad often. A tip is to be careful downloading free converters as there are quite a few viruses around. (Depending on geometry, you could also try to import the dwg to your preferred 3d software and do feature recognition or similar and then export to stl from there instead) Good luck!
Yes. With third-party programs Rhino type.
contact me to convert it iblaprotolab@gmail.com
