This is our latest product, a larger print size, we upgraded the hot end, use E3D-V6 nozzle (0.4mm), can be more easily disassembled and cleaned.
Print size(X,Y,Z): 280×280×600mm
Nozzle diameter: 0.4 mm (E3D-V6)
Nozzle number: single nozzle The maximum temperature of the nozzle is:280℃
Software: Repetier host
Control board: Mega 2650 + RAMPS 1.4 + A4988 stepper driver + 2004LCD + USB + SD card
We have developed a bigger size heated bed, to meet more printed material.
Automatic leveling system is being developed, will soon be used.
HE3D Delta -600 3d printer kit
sales@reprapmall.com
Technical parameters:
1.Integrated SD card with LCD monitor display.
2.The Layer Thickness: 0.05-0.4mm
3.Layer Resolution: 50 microns
4.Printing Filament: PLA & ABS. Heatbed Required for ABS.
5.Technology: Fused Deposition Molding (FDM).
6.Construction based on parallel arm (delta).
7.Machine dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
8.Outer frame: imported aluminum, steel (laser precision cutting)
9.Extruder:remotely and high-speed extrusion machine
10.The print head material: copper, aluminum, polyether ether ketone material forming
11.Nozzle diameter: 0.4 mm (E3D-V6) Nozzle temperature: 280℃(max)
12.Filament diameter: 1.75mm
13.Nozzle number: single nozzle
14.Data format: STL
15.Software: Repetier host
16.Print size(X,Y,Z): 160×160×230mm
17.Power input: AC110-220 - v
18.The power supply output: DC 12 v 7 a
19.Print plate: high borosilicate glass 180 mm in diameter
20.Synchronous belt wheel / 16 teeth, belt GT2
21.Upgradable to heatbed.
