For the first time in history the majority of the world’s population live in cities. With the hustle and bustle of city life comes a lack of space for gardens and agriculture. We’ve teamed up with friends @3dprintler, an Ottawa based startup, to distribute a 3D Printed solution!
3Delicious Food
3DPonics, recently successfully funded on Kickstarter, is a hydroponics system composed of 3D-printed components, waste plastic bottles and few cable ties here and there! The project aims to eliminate the need for a garden and will let you grow food even if you don’t have a backyard - you can set it up pretty much anywhere, on your balcony or even in your living room! Grow your own tomatoes, herbs… let nature do the hard work for you! Best of all, 3Dponics is completely free and open source.
Make your own
1. Print your parts
Download the 3DPonics STL files here. You can either print these on your 3D printer or directly at 3D Hubs below!
4 Drip Nozzles
Conduit
Silencer
Sprinkler
Sprinkler Head
Pump Connector
Height Adjuster
Outer Clip
Inner Clip
2. Collect your materials
You will also need…
4 plants (tomatoes, cucumbers, green peppers, herbs, etc.)
4 empty plastic bottles
Hydroponics growth medium (grow stones or equivalent) (pre-soaked for a couple of days)
Aeration kit for aquariums
Vertical support column for tubing (bamboo works well!)
Air pump
Rubber tubing for an aquarium air pump or similar
Zip ties
Support structure (coat rack or a ceiling hook recommended)
Scissors
A water jug (4 L, 8 L or 9 L recommended)
Hole puncher
Utility knife
3. Full instructions of how to assemble you hydroponics system can be found here.
4. Eat your greens…
The future is hydroponics
Some users have already created clever hooks, supports and bottle covers for the system. Founder Michael Golubev is already looking to the future ‘we foresee a hydroponics system that’s Internet-enabled with sensors, timers, pH meters and cameras that optimise yield, reduce operation costs and allow you to operate the system remotely.’ This is just the beginning for 3DPonics.
