hi there,
I got my anycubic kossel linear plus the weekend and started printing.
So far I found out printing a brim is a bad bad idea as it is hard to remove from the heatbedcover
Bed leveling was a pain but finally worked. The autolevel hepls but correcting -Z values is difficult due the small step size and it seems to forget my stored values sometimes. But now it works.
But I have mature problems in print quality not sure why.
Using cura 3.1 as from ubuntu linux sources I sliced models from thingiverse.
Al are printed (30mm/sec) in thin layer .12…15mm but I get broken surfaces.
Trying to print a closed torus like object (filament cooler) the outer walls are very thin, the material (PLA) is in fine layers but the outer walls are not fully closed and have sponge-like small openings all over.
Anyone in here might tell me his cura version and settings (screenshot maybe) for good print results with the Kossel printer?
Thanks in advance!
. I found a Cura profile online and uploaded it… After a couple pathetic Benchys, I decided to check the machine settings. What I found made me wonder.
