Cubify Printers
So the last comment, all the sales are by PayPal, what gives 100% moneyback warranty … so very strange, 3 Years, 46 countries, the devices don’t work ? afffff
I want nothing more than to find a lesser expensive option - I own two cube 3’s. But I do not want to throw that much money at something only to find it doesn’t work. So based on that I need some level of comfort that it really does work, and after looking a bunch I am not even close to being there.
I’m just saying I am looking for evidence from other 3D systems printer owners that they are using your device and are happy with it. I cannot find any.
You will find on the net angry people or false information. Satisfied people just use and be happy, don’t think to post affff
We are developing a low cost solution, so ASAP I will let you know … thanks
How far off are we? Cube3 users are ready to ditch the system and move on and not wait
fuck
I know that the time is a problem, but the intention to put an encrypted chip to make the printer slave of the original cartridges is to delay the bypass system
Hi josh, are you trying to print the original files that came with the USB stick? Make sure they are good because they were sent out wrong from the factory
Spencer, I sucessfully completed the filament hack last week. Using an empty modified cartridge to feed the standard filament and a 1-3% full cartridge for tricking the printer. I have a video that I will post maybe this week, but to give you the process so you can try yourself here it is:
1. Insert the 1-3% cartridge and start a print (1-3% is important because the printer will notify that there isnt enough filament to finish the job)
2. Select the checkmark to proceed
3. When the screen says apply glue, remove the cartridge and replace with the hacked cartridge. (dont forget the glue)
4. Select checkmark to proceed (the printer will begin the heatup process and begin the print)
Important to remeber:
1-3% cartridge, hacked cartridge and standard filament all need to be the same material- PLA for instance.
There are a few different ways people have hacked the cartridge, but I chose the simple way. Drill a hole near the bottom of the cartridge at an angle (toward the extruder). This is so you can feed the teflon tube that guides the filament to the extruder thru the cartridge casing (cartridge does come apart for access to the teflon tube which you already know if youve had to fix a jam). Feed the standard filament into this tube up thru the extruder and to the hot end. You will need a spool holder for the standard filament.
One thing I do not know yet is how different colors act. I say this because I was charting temps on the 3D systems filament and they seem to vary a bit and also ran at higher temps than typical. The standard PLA I ran though was right in the middle of the manufacturers recommended temp range, so I was happy about that. I used Inland Neon Green.
Hopefully the video will help clarify if necessary, but feel free to ask questiion if needed.
Rick I’ve been doing this however I seem to still get a countdown on the “second” cartridge.
Email me me so we can chat a little easier.
Th3designlab@gmail.com
Be careful CUBE3DFREE is a thief
he sells card that doesn’t work whith 3D printer Cube
You are a crimminal person, posting false information. There are more than 500 modules working worldwide … probably you are someone related to 3DS … be careful because I will report you to the authorities
Hello i am a french teacher in electronic
I bought a card for my cubepro duo
The card dosn’t work !!!
It is a shame and the seller said that i don’t know how to use it
now i have a litige on paypal, don’t buy this expensive sheet
He told me to send the card in Italy and now it is magic he say’s that work ???
I have a litige in paypal with this person i want to be refill
i am a criminal ?
And sell a ship 240USD which dosn’t work ? What it is ?
You are a crimminal french teacher … The module you sent to Italy is now working into another CubePro.
Whar you will say to people that have it working ? You was paid by someone to post this kind of things to afraid people.
i am no pay has you say
i bought you card for my printer
it dosn’t work
i want to be refill, i send you the card now i wait my money and i will continu to INFORM
Be carfeful of the seller CUBE3DFREE it is thief
the card doesn’t work
I have a cubepro duo with firmware 2.00
i am not a criminal
i just INFORM that you are a thief
CUBE3DFREE dosn’t work !!! Don(t buy this expensive item
For information i a a french électronic teacher, if someone want a evidence that is not a problem
Don’t trust this personn
